![gen4-4DPi Series – Primary Displays for the Raspberry Pi gen4-4DPi Series – Primary Displays for the Raspberry Pi](https://www.electronics-lab.com/wp-content/uploads/2018/02/0b79ca15-17dc-487e-aef3-166186745a99.png)
The gen4-4DPi range are Primary Display’s for the Raspberry Pi* A+, B+, Pi2, Pi3, Pi Zero and Pi Zero W, which display the primary output of the Raspberry Pi, like what is normally sent to the HDMI or Composite output. It features an integrated Resistive Touch panel or Capacitive Touch panel, enabling the gen4-4DPi to function with the Raspberry Pi without the need for a mouse.
Features:
- Universal Primary Display for the Raspberry Pi
- Compatible with Raspberry Pi A+, B+, Pi2, Pi3, Pi Zero and Pi Zero W
- 480×272 Resolution (4.3”)
- 800×480 Resolution (5.0” & 7.0”)
- TFT Screen with integrated 4-wire Resistive Touch Panel (T), or Capacitive Touch Panel (CT)
- Display GUI output / primary output, just like a monitor connected to the Raspberry Pi
- High Speed 48MHz SPI connection to the Raspberry Pi, featuring SPI compression technology
- Typical frame rate of 20 Frames per second (FPS) – 4.3”, or 7 Frames per second (5” & 7”), higher if image can be compressed further by the kernel. Lower if no compression is possible
- Powered directly off the Raspberry Pi, no external power supply is required
- On board EEPROM for board identification, following the HAT standard
Available in:
- gen4-4DPi-43T (4.3” Resistive Touch)
- gen4-4DPi-50T (5.0” Resistive Touch)
- gen4-4DPi-70T (7.0” Resistive Touch)
- gen4-4DPi-43CT (4.3” Capacitive Touch)
- gen4-4DPi-50CT (5.0” Capacitive Touch)
- gen4-4DPi-70CT (7.0” Capacitive Touch)
website: www.4dsystems.com.au
Login
