![GNSS Modules: Elara and Erinome GNSS Modules: Elara and Erinome](https://www.electronics-lab.com/wp-content/uploads/2020/07/gnss-ics.jpg)
Würth Elektronik’s GNSS modules, Elara and Erinome series, are suitable for different application areas, such as tracking and navigation devices, container localization, fleet management or autonomous agricultural machines.
Elara Modules:
The Elara-I module is a compact GNSS module with an integrated antenna for operation in location-based applications, products, and services. Based on the Qualcomm SirfStar V 5e B01 chipset, it supports two major GNSS constellations (GPS and GLONASS). The integrated antenna on top of the Elara-I module allows easier hardware integration, as no effort for antenna integration and matching is required. The compact 10 mm x 10 mm design allows the module to fit in small-size applications.
The Elara-II module is a compact GNSS module for operation in location-based applications, products, and services. Based on the Qualcomm SirfStar V 5e B01 chipset, it supports two major GNSS constellations (GPS and GLONASS). The Elara-II is one of the smallest GNSS modules currently on the market with an ultra-compact 4.1 mm x 4.1 mm design which allows the module to fit in small-size applications. The connection of an external antenna through the RF pad is required for module operation.
Erinome Modules:
The Erinome-I module is a compact GNSS module with an integrated antenna for operation in location-based applications, products, and services. Based on the Qualcomm SirfStar V 5e B02 chipset, it supports four major GNSS constellations (GPS, GLONASS, Galileo, and BeiDou) for fast and accurate positioning. The integrated antenna on top of the Erinome-I module allows easier hardware integration, as no effort for antenna integration and matching is required. The compact 18 mm x 18 mm design allows the module to fit in small-size applications.
The Erinome-II module is a fully-featured GNSS module with an external antenna connector. The module is based on Qualcomm SirfStar V 5e B02 chipset and it supports four major GNSS constellations (GPS, GLONASS, Galileo, and BeiDou) for fast and accurate positioning. The ultra-compact 7 mm x 7 mm design allows the module to fit in small-size applications. The connection of external antenna through the RF pad is required for module operation.
- Two of the smallest GNSS modules available: Elara-I and Elara-II
- Integrated/external antenna variants
- Multi-GNSS (+SBAS and QZSS) supported
- High update rate: up to 10 Hz
- Low-power modes
- UART and I²C interfaces
- EDA libraries
- Tracking and navigation devices
- Container localization
- Fleet management
- Location support for rescue
- Cartography
- Autonomous agricultural machines
- Geotagging for digital cameras
- Animal tracking
- Time reference for worldwide events/machine synchronization
Resources
