![GTR6 mini PC from Beelink Features AMD Ryzen 9-6900HX Processor, 8K Quad Display Support, WiFi 6, Bluetooth 5.2 and up to 64GB RAM GTR6 mini PC from Beelink Features AMD Ryzen 9-6900HX Processor, 8K Quad Display Support, WiFi 6, Bluetooth 5.2 and up to 64GB RAM](https://www.electronics-lab.com/wp-content/uploads/2022/10/Beelink-GTR6-e1667280673214.webp)
Beelink has recently launched one of the most powerful mini PC that we have come across so far, powered by a 45W AMD Ryzen 9 6900HX 8-core, 16-thread processor running at up to 4.9 GHz with up to 64GB DDR5-4800MHz and M.2 2280 PCIe Gen 4 SSD storage: the GTR6 6900HX mini PC.
Integrated within the AMD Ryzen 9 6900HX mobile processor is a 12-core Radeon 680M GPU clocked at up to 2400MHz with up to 2GB memory. This powerful GPU is said to have a performance that exceeds many entry-level desktop graphics cards. It is very fast and can run almost all 3A games smoothly at Full HD resolution.
Other features include WiFi 6, Bluetooth 5.2 support, 2.5 GbE LAN port, four HDMI 2.1 video ports supporting four simultaneous displays with 8K/60Hz resolution, one M.2 2280 slot supporting a PCIe 4.0 x4 SSD and another M.2 2280 slot supporting SATA 3 SSDs. On top of the GTR6 is also a unique 0.5s fingerprint recognition sensor for biometric security and quick unlocking.
The GTR6 also adopts patent cooling technology to handle heat dissipation issues. So, it does have a silent cooling fan that runs at 2600 RPM at full CPU load as well as a heat sink.
Specifications:
- CPU: AMD Ryzen 9 6900HX (8 cores, 16 Threads, 3.3GHz to 4.9GHz, 16M L3 Cache)
- GPU: AMD Radeon 680M Graphics (12 Cores, 2400MHz frequency, up to 2GB memory)
- Up to 64GB DDR5-4800MHz Dual-channel So-DIMM
- 1x M.2 2280 NVMe PCIe 4.0 (up to 2TB)
- 1x 2.5 inch SATA 3.0 (6.0 GB/s)
- WiFi 6E (1.2 Gbps)
- Bluetooth 5.2 Support
- 1x 2.5 GbE RJ45 LAN port
- 4x HDMI 2.1 video output up to 8K@60Hz, support for up to four independent 8K display
- 1x 3.5 mm Audio jack, digital audio via HDMI ports
- 1x USB 3.0 Type-C ports
- 3x USB 3.0 Type-A ports
- 2x USB 2.0 Type-A ports
- Heatsink and Cooling fan @ 2600 RPM under full CPU load
- 0.5s fingerprint unlock system
- Power: 120W, 19A/6.32A via DC jack
- Dimensions: 68 mm x 120 mm x 43 mm
Pricing and Availability
You can get the GTR6 mini PC for either $539 (a barebone model with no memory or storage) or $749 (a second model with 32GB RAM and 500GB SSD). The mini PC comes preloaded with Windows 11 and you can also install Linux distributions of your choice such as Ubuntu, CentOS, and OpenSUSE. Shipping is expected to start by the end of November this year.
