![GW16146 802.11ah HaLow WiFi Mini-PCIe Radio GW16146 802.11ah HaLow WiFi Mini-PCIe Radio](https://www.electronics-lab.com/wp-content/uploads/2021/09/Screenshot-2021-09-23-at-11-01-19-GW16146-802-11ah-HaLow-WiFi-Mini-PCIe-Card-Gateworks-Corporation-Single-Board-Computers.png)
Gateworks is proud to announce the GW16146 802.11ah HaLow Mini-PCIe radio for the industrial internet of things (IoT) applications. It uses the Silex SX-NEWAH module, which is based on the Newracom NRC7292 System-on-Chip. The GW16146 brings all the advantages of 802.11ah to the Gateworks rugged and industrial single board computers.
802.11ah, often called Wi-Fi HaLow, is a new standard that uses Sub-1GHz frequencies to provide a longer range at lower power consumption. It can support 1000’s of clients with WPA-3 security. By utilizing a standard TCP/IP framework, no special code or SDKs are required. With everything being open source and unlicensed, no costly consortium memberships are required.
802.11ah HaLow Mini-PCIe Radio Highlights:
- Long Range
- Unlicensed frequency band – Sub 1-GHz
- Standard TCP/IP Framework – No special software is needed
- Low Power
- WPA-3 Security
- Supports 1000’s of clients
- Open software standard
- Drivers and software pre-loaded on Gateworks SBCs
more information: https://www.gateworks.com/products/mini-pcie-expansion-cards/gw16146-802-11ah-halow-wifi-mini-pcie-card/
