![GYPRO® high performance MEMS gyroscopes GYPRO® high performance MEMS gyroscopes](https://www.electronics-lab.com/wp-content/uploads/2019/01/GYPRO.png)
The GYPRO® high performance MEMS gyroscopes product line has been specifically designed for applications that are more demanding than automotive, while not requiring ‘tactical grade’ FOG (Fiber Optic Gyros) or DTG (Dynamically Tuned Gyros). GYPRO® offers high bias stability, low noise and low latency. The closed-loop gyroscopes product family is well suited to precision navigation and stabilization applications.
We are delighted to have our high performance MEMS gyros now part of Premier Farnell’s portfolio of inertial sensing solutions. Partnering with such a key distributor will strengthen the exposure of our standard inertial products as well as our recognized expertise in this field”, said Vincent Gaff, Tronics’ Director Marketing and Business Development.
This move will further structure our supply chain at global level thanks to Premier Farnell’s reliable and responsive distribution capabilities, and will open up new opportunities for worldwide customers eager to integrate our current and future generation of high performance standard inertial products into their targeted applications.
Tronics high performance MEMS inertial sensors are ideally suited for system manufacturers with strong requirements for high bias stability and high-performance inertial sensors. Key applications include precision navigation, motion tracking and control, and optical stabilisation. Tronics’ comprehensive sensor portfolio brings a tailored solution to support system manufacturer’s transition to MEMS products, with huge benefits in terms of size, weight, power and price, without compromising on performance and reliability.
The Tronics’ GYPRO® series combines several key benefits on a single chip, and features bias instability of only 0.8̊ per hour and ultra-low noise (Angular Random Walk) of only 0.14° per √h. The standard GYPRO2300 product features a data rate of 200 Hz with RMS Noise [1-100Hz] of 0.02°/s; the GYPRO2300LD offers a data rate of 1700 Hz at 2ms latency tailored for motion tracking and stabilisation. The GYPRO3300 boasts improved tolerance to harsh environments (vibration rectification coefficient of 0.5°/h/g²) and a latency of 1ms due to improved integrated circuitry, tailored for precision navigation and stabilisation.
The built-in closed-loop electronics brings several key advantages, including superior linearity, increased signal to noise ratio and improved behaviour in harsh vibration, shock and temperature environments.
Tronics standard products are manufactured at the company’s Crolles facility near Grenoble, France, and calibrated over a broad temperature range, allowing for high-accuracy digital output.
Specifications
- Z-axis angular rate sensor
- ±300°/s range
- 24-bit SPI output
- Single 5V power supply
- 0.8°/h Bias stability (Allan Variance)
- 0.14°/sqrt(h) ARW (Angular Random Walk)
- Built-in temperature compensation [-40 to +85°C]
more information: www.tronicsgroup.com
