Hardkernel’s ODROID-H4, H4+ and H4 Ultra SBC’s Features Intel N97, and i3-N305 and Intel SoC
1.205
In a recent update, Hardkernel added three new SBCs to their ODROID series the ODROID H4, ODROID H4+, and ODROID H4 Ultra. The ODROID H4 and the H4+ features a 4-core Intel N97 processor, while the flagship H4 Ultra utilizes the 8-core Intel i3 N305 processor.
The N97 is an Intel processor with 4 cores (4C) operating at a clock speed range of 2.0 – 3.6 GHz. It has 6MB of cache memory, a low power consumption of 12W TDP, and integrated Intel UHD Graphics (reaching up to 1.20 GHz) with 24 Execution Units.
In comparison, the Core i3-N305 boasts 8 cores and 8 threads (8C/8T), a clock speed range of 1.8 – 3.8 GHz, 6MB of Smart Cache, slightly higher power consumption at 15W TDP, and Intel UHD Graphics (peaking at 1.25 GHz) with a greater number of Execution Units at 32.
Hardkernel’s ODROID series SBCs feature Intel N97 processor and i3 N305 processor with adequate RAM, 2.5G Ethernet, IO options and more.
The units have DDR5 SO-DIMM slots supporting up to 4800 MT/s and 48GB capacity. Storage includes eMMC connectors and options for SATA3 ports and an M.2 slot. Networking features two 2.5 GbE LAN ports with Wake-On-LAN. Display support includes triple 4K@60Hz. Audio capabilities include dual 3.5mm jacks and SPDIF out. Connectivity offers USB 3.0, USB 2.0 ports, and a 24-pin expansion header for UART and I2C.
Hardkernel’s ODROID H4, H4+ and H4 Ultra Specifications
SpecificationsODROID H4ODROID H4+ODROID H4 Ultra
CPU (Intel)Processor N97Processor N97Core™ i3 Processor N305
Code nameAlder Lake-NAlder Lake-NAlder Lake-N
Launch dateQ1’23Q1’23Q1’23
MicroarchitectureGracemontGracemontGracemont
Cores / Threads4C4T4C4T8C8T
Cache6 MB6 MB6 MB
AVX2 (Advanced Vector Extensions)YesYesYes
TDP12W12W15W
Single Thread Burst Frequency (GHz)3.63.63.8
Max. Memory address space (GB)484848
Max. Memory Speed (MT/s)DDR5-4800DDR5-4800DDR5-4800
Burst Frequency (MHz)120012001250
Execution Units242432
Video outputs
HDMI111
DisplayPort222
PCIe (via NVMe slot)
GenerationGen 3Gen 3Gen 3
Lanes444
Compatibility with optional  4-ports 2.5GbE and Net CardYesYesYes
USB 2.02 ports2 ports2 ports
USB 3.02 ports2 ports2 ports
2.5GbE1 port2 ports2 ports
SATA IIINo4 ports4 ports
24pin IO Expansion portsI2C x 2, USB 2.0 x 3, UART x 1, HDMI-CEC x 1, Ext. Power Button x 1I2C x 2, USB 2.0 x 3, UART x 1, HDMI-CEC x 1, Ext. Power Button x 1I2C x 2, USB 2.0 x 3, UART x 1, HDMI-CEC x 1, Ext. Power Button x 1
Optional Cooling FanSlim 92-15 or thick 92-25 mm 12 Volt standard PC 4-pin fan - slim fan fits inside the new cases.Slim 92-15 or thick 92-25 mm 12 Volt standard PC 4-pin fan - slim fan fits inside the new cases.Slim 92-15 or thick 92-25 mm 12 Volt standard PC 4-pin fan - slim fan fits inside the new cases.
Recommended Power Supply 160W60W60W
Recommended Power Supply 2133W133W133W
Unlimited Performance ModeYesYesYes
Security (TPM 2.0)---
Hardkernel H-series casesDIY assembly The cases are made of solid and sturdy PCBs.DIY assembly The cases are made of solid and sturdy PCBs.DIY assembly The cases are made of solid and sturdy PCBs.
A classic GameCube-style case will be released in May or June separately.A classic GameCube-style case will be released in May or June separately.A classic GameCube-style case will be released in May or June separately.
CertificationsFCC/CE/KC/RoHSFCC/CE/KC/RoHSFCC/CE/KC/RoHS
Pricing99139220
Dimensions120x120mm (4.7×4.7 in)120x120mm (4.7×4.7 in)120x120mm (4.7×4.7 in)
The series has passive heatsinks and optional cooling fans for efficient thermal management. It supports 15V/4A or 19V/7A power adapters in a compact 120mm x 120mm x 47mm size. In Unlimited Performance mode, H4 and H4+ show a 36% improvement over H3+, while H4 Ultra shows an 83% improvement due to advanced cooling and design.
The ODROID-H4 series offers versatility and customization with various memory, storage, and connectivity options. Additionally, it supports Windows, Linux, and Android, catering to diverse user needs.
The base model of the Hardkernel’s ODROID H4 will cost you only $99.00. The H4+ can be bought for $139.00, the CPU, RAM, and Networking options make it suitable for a NAS and the $220.00 H4 Ultra is suitable for those who are going to use this in CPU and GPU-intensive tasks. The company also provides technical documentation, code examples, and others which can be found on their Wiki page. For additional details, check the product announcement on the Odroid forum.
About Debashis Das
view all posts by das
