![Heat Activated Cooling Fan Controller Heat Activated Cooling Fan Controller](https://www.electronics-lab.com/wp-content/uploads/2016/07/002.jpg)
Heat activated cooling fan controller is a simple project which operates a brushless fan when the temperature in a particular area goes above a set point, when temperature return normal, fan automatically turns off. The project is built using LM358 Op-amp and LM35 temperature Sensor. Project requires 12V DC supply and can drive 12V Fan. This project is useful in application like Heat sink temperature controller, PC, heat sensitive equipment, Power supply, Audio Amplifiers, Battery chargers, Oven etc
Heat Activated Cooling Fan Controller – [Link]
Login
