![High-performance ARM SoM Powered by NXP i.MX 8M High-performance ARM SoM Powered by NXP i.MX 8M](https://www.electronics-lab.com/wp-content/uploads/2019/06/MYC-JX8MX_2.png)
Shenzhen, China – June 11, 2019 – MYIR introduces a high-performance ARM SoM MYC-JX8MX CPU Module, which is built around the NXP i.MX 8M Quad processor featuring 1.3GHz quad ARM Cortex-A53 cores and a real-time ARM Cortex-M4 co-processor. The module runs Linux and is capable of working in extended temperature ranging from -30°C to 80°C.
Measuring 82mm by 52mm, the MYC-JX8MX CPU Module has integrated 1GB/2GB LPDDR4, 8GB eMMC, 256Mbit QSPI Flash, Gigabit Ethernet PHY and PMIC on board. A large number of I/O signals are carried to or from the i.MX 8M CPU Module through one 0.5mm pitch 314-pin MXM 3.0 expansion connector, making it an excellent embedded solution for Scanning/Imaging, Building Automation and Smart Home, Human Machine Interface (HMI), Machine Vision and more other consumer and industrial applications which requires high multi-media performance.
![](https://www.electronics-lab.com/wp-content/uploads/2019/06/MYC-JX8MX_3.png)
MYIR also offers a versatile platform MYD-JX8MX development board for evaluating the MYC-JX8MX CPU Module. It takes full features of the i.MX 8M processor and has brought out rich peripherals through connectors and headers such as 4 x USB 3.0 Host ports and 1 x USB 3.0 Host/Device port, Gigabit Ethernet, TF card slot, USB based Mini PCIe interface for 4G LTE Module, WiFi/BT, Audio In/Out, HDMI, 2 x MIPI-CSI, MIPI-DSI, 2 x LVDS display interfaces, PCIe 3.0 (x4) NVMe SSD Interface, etc. It is delivered with necessary cable accessories for customer to easily start development as soon as getting it out-of-box.
![](https://www.electronics-lab.com/wp-content/uploads/2019/06/MYC-JX8MX_block_diagram.png)
Mechanical Parameters
- Dimensions: 50mm x 82mm
- PCB Layers: 10-layer design
- Power supply: +5V/0.5A
- Working temperature: -30~80 Celsius
Processor
- NXP i.MX 8M Quad Processor based on 1.3GHz Quad ARM Cortex-A53 and 266MHz Cortex-M4 cores
(MIMX8MQ6CVAHZAB by default)
Memory
- 1GB / 2 GB LPDDR4 (supports up to 4GB LPDDR4)
- 8GB eMMC Flash (supports up to 64GB eMMC)
- 256Mbit QSPI Flash
Peripherals and Signals Routed to Pins
- One 10/100/1000Mbps Ethernet PHY
- Power Management IC (ROHM BD71837MWV)
- 0.5mm pitch 314-pin MXM 3.0 Expansion Connector
– 1 x 10/100/1000Mbps Ethernet
– 3 x Serial ports
– 3 x I2C
– 2 x SPI
– 4 x PWM
– 3 x USB 3.0
– 2 x PCIe
– 6 x I2S / SAI
– 2 x MIPI Camera Sensor Interface
– 1 x JTAG
– 1 x HDMI 2.0a output
– Up to 108 GPIOs
![](https://www.electronics-lab.com/wp-content/uploads/2019/06/2.jpg)
![](https://www.electronics-lab.com/wp-content/uploads/2019/06/MYD-JX8MX-Development-Board_block_diagram.png)
MYIR offers 1GB or 2GB RAM selections for the CPU modules and development boards which have very-high powered prices to compare.
More information about the new products can be found at:
- http://www.myirtech.com/list.asp?id=607 (MYC-JX8MX)
- http://www.myirtech.com/list.asp?id=608 (MYD-JX8MX)
