![High Side Switch with Input Overvoltage and Overcurrent Protection High Side Switch with Input Overvoltage and Overcurrent Protection](https://www.electronics-lab.com/wp-content/uploads/2021/04/3.jpg)
The project here is a 48V protected, high side switch designed to switch a 5A output load from input voltages from 8V to 48V. The circuit helps the user to easily ON/OFF the high current and voltage load with over-voltage lockout and over-current protection. The wide input range and low shutdown current (1μA typical) make it suitable for automotive, industrial, medical instruments, and telecom applications. This board offers a low 50ns (typical) propagation delay, fast switching times (<10ns), and 100% duty cycle operation. The project is based on LTC7000 which is a fast high voltage protected high side N-channel MOSFET driver. An internal charge pump fully enhances an external N-channel MOSFET switch, allowing it to remain on indefinitely. Its powerful gate driver can drive large gate capacitance MOSFETs with very short transition times, ideal for both high-frequency switching and static switch applications.
High Side Switch with Input Overvoltage and Overcurrent Protection – [Link]
