![High Voltage Regulator – 48V DC Output from 125V DC Input High Voltage Regulator – 48V DC Output from 125V DC Input](https://www.electronics-lab.com/wp-content/uploads/2020/03/IMG_4666.jpg)
The project published here is a high-voltage adjustable regulator with an output 48 V DC from an input supply of 125V DC. The circuit is capable to drive load current up to 500mA. This regulator circuit designed for use in high-voltage applications where standard bipolar regulators cannot be used. Excellent performance specifications, superior to those of most bipolar regulators, are achieved through circuit design and advanced layout techniques. As a state-of-the-art regulator, the TL783 device combines standard bipolar circuitry with high-voltage double diffused MOS transistors on one chip, to yield a device capable of withstanding voltages far higher than standard bipolar integrated circuits. Because of its lack of secondary-breakdown and thermal-runaway characteristics usually associated with bipolar outputs, the TL783 maintains full overload protection while operating at up to 125 V from input to output. Other features of the device include current limiting, safe-operating-area (SOA) protection, and thermal shutdown.
High Voltage Regulator – 48V DC Output from 125V DC Input – [Link]
