This is an internet speed Analyzer based on Raspberry Pi:
This application will run speedtest-cli against speedtest.net’s servers using cron. It will then email the results daily and weekly.
Also – using http://www.percheron-electronics.uk/shop/ e-paper hat – you can utilize the buttons to run the speed-test manually and display the results to the screen.
To use the device you will need a few bits installed to your Raspberry Pi. You can see the full list below, but if you just want to get started, see the simple instruction below:
How to Make an Internet Speed Analyzer – [Link]
Login
