![Humidity sensor using 8051 Humidity sensor using 8051](https://www.electronics-lab.com/wp-content/uploads/2015/10/humidity-sensor-e1443683380265.png)
by circuitstoday.com:
This project is about a simple humidity sensor based on 8051 microcontroller. Humidity sensor is also called hygrometer. This circuit can sense relative humidity (RH) from 20% to 95% at an accuracy of 5%. The humidity information is displayed on a 16×2 LCD display. A relay is also provided which is set to be active when the humidity crosses a certain trip point. The circuit is mains operated and it is very easy to install. DHT11 is the humidity sensor used here. The details and working of the DHT11 humidity sensor is given below.
Humidity sensor using 8051 – [Link]
Login
