TDK Invensense’s 6-axis MotionTracking device enables manufacturers to eliminate the need for system-level integration of discrete devices
TDK Invensense’s IAM-20680HP is a 6-axis MotionTracking device for automotive applications that combines a 3-axis gyroscope and a 3-axis accelerometer in a small 3 mm x 3 mm x 0.75 mm (16-pin LGA) package. It also features a 4096-byte FIFO that can lower the traffic on the serial bus interface and reduce power consumption by allowing the system processor to burst read sensor data and then go into a low-power mode. Its 6-axis integration enables manufacturers to eliminate the costly and complex selection, qualification, and system-level integration of discrete devices, guaranteeing optimal motion performance.
- Digital-output X-, Y-, and Z-axis angular rate sensors (gyroscopes) with a user-programmable full-scale range of ±250 dps, ±500 dps, ±1000 dps, ±2000 dps, and integrated 16-bit ADCs
- Digital-output X-, Y-, and Z-axis accelerometer with a full-scale programmable range of ±2 g, ±4 g, ±8 g, ±16 g, and integrated 16-bit ADCs
- User-programmable digital filters for gyroscope, accelerometer, and temperature sensor
- Embedded self-test
- Wake-on-motion interrupt for low power operation of applications processor
- Reliability testing performed according to AEC-Q100: PPAP and qualification data available upon request
- Final test at -40°C, +25°C, and +105°C
- Burn-in in production
more information: https://invensense.tdk.com/products/motion-tracking/6-axis/iam-20680/
