![iBASE IB952 – A 3.5-inch SBC with AMD Ryzen Embedded V2000 Processors iBASE IB952 – A 3.5-inch SBC with AMD Ryzen Embedded V2000 Processors](https://www.electronics-lab.com/wp-content/uploads/2024/02/IB952-3.5-inch-SBC-with-AMD-Ryzen-Embedded-V2000-Series-Processors-e1708790698583.png)
iBASE IB952 is a 3.5-inch single-board computer (SBC) powered by the AMD Ryzen Embedded V2000 processors. The device supports up to 64GB DDR4 RAM, dual Gigabit Ethernet, and four 4K displays via AMD Radeon Vega graphics, all these features make this board suitable for enhanced computing and IoT applications like POS, digital signage, and factory automation.
The AMD Ryzen Embedded V2000 series processors are built on the “Zen 2” architecture with a 7nm process, featuring up to 8 cores and 16 threads, integrated Radeon Vega graphics, and designed for high-performance, low-power embedded applications.
The board comes with a TPM chip for extra security and offers lots of connection options like USB ports, SATA connections for storage, serial ports for older devices, and M.2 slots for fast storage or other expansions. It works with both Windows 10 and Linux Ubuntu, giving you flexibility in choosing your operating system.
iBASE IB952 SBC Specifications:
- CPU: AMD Ryzen Embedded V2000 series processor onboard
- PCH: Not applicable
- Memory: Supports DDR4-3200 SO-DIMM up to 64GB, ECC compatible
- BIOS: AMI
- Watchdog Timer: Supports 256 levels
- Hardware Monitoring: Yes
- Storage Device Interface:
- 1x M.2 (M-Key) for storage
- Mini Type Slots:
- 1x M.2 (M-Key, type 2280, supports NVMe)
- 1x M.2 (E-Key, type 2230)
- Graphics Controller: AMD Radeon™ Vega integrated graphics
- Video Output:
- 2x DisplayPort (DP connector & Type-C)
- 1x 24-bit Dual-channel LVDS
- 1x eDP (Embedded DisplayPort)
- Ethernet: 2x Intel® I211AT or I210AT Gigabit LAN
- I/O Chipset: Fintek F81964
- Serial Ports:
- 1x RS232/422/485 (Jumper-less selection)
- 3x RS232
- USB Ports:
- 2x USB 2.0 onboard
- 3x USB 3.1 onboard
- Serial ATA: 2x SATA III
- Audio: Built-in audio with Realtek ALC888S
- TPM: TPM 2.0 for security
- Other Features:
- Digital I/O (4-in/4-out)
- EuP/ErP compliant
- Power input: +12V~+24V DC-in (+/-10%)
- Dimensions: 102mm x 147mm (4″ x 5.8″)
- Power Consumption:
- AMD Ryzen™ Embedded V2748 2.9GHz with 2x 16GB DDR4-3200: +12V, 7.61A
- AMD Ryzen™ Embedded V2718 1.70GHz with 2x 16GB DDR4-3200: +12V, 3.92A
- Operating Temperature: 0°C~60°C (32°F~140°F)
- Storage Temperature: -20°C~80°C (-4°F~176°F)
- Relative Humidity: 95% non-condensing at 60°C
For the IB952, you’ll find datasheets, manuals, and an embedded computing catalog for setup and info. It supports Windows 10 drivers for the AMD V2000 APU, AMD graphics, Realtek audio, and Intel I211-AT LAN, ensuring smooth operation.
At the time of writing iBASE did not release any pricing information for this particular SBC, but more information can be found on their products page.
