![iCE40UP5K in a Feather compatible form factor iCE40UP5K in a Feather compatible form factor](https://www.electronics-lab.com/wp-content/uploads/2019/08/top_render.png)
iCE40UP5K is a developement board in a Feather compatible form factorb by Josh Johnson
- iCE40UP5k FPGA in a QFN-48 package
- 5280 Logic Cells
- 20 IO broken out to Feather, 4 additional IO on bottom of board
- FT2232 provides programming and UART interface over a Micro USB connector
- 32 MBit SPI Flash
- Onboard RGB LED, user LED, TX/RX LEDs
Additional FeatherWings
- 6×6 LED Matrix + 4 Buttons + RGB LED
- DIP Switch + 7 Segment Display
- Feather to Dual PMOD breakout
Software
- Compatible with the open source IceStorm toolchain
- Thanks to Piotr Esden-Tempski and his iCEBreaker examples as a starting point for the firmware development.
Login
