![IMB-1215 Coffee Lake – Mini-ITX Intel® Core™ 8th Gen Q370 SBC IMB-1215 Coffee Lake – Mini-ITX Intel® Core™ 8th Gen Q370 SBC](https://www.electronics-lab.com/wp-content/uploads/2019/02/IMB-1215L2-1024x853.png)
Overview
The IMB-1215 is the lower cost ‘brother’ of the IMB-1213.
As you’ll see the IMB-1215 still retains a lot of the main features of the “full spec” IMB-1213 but with minor modifications around power, for example, where the standard is single power input (19V DC in) versus the standard wider range power input (12V/19V ~ 28V) of the IMB-1213.
Although there’s still the selectable option to go for a wider power input of 19V ~ 28V on the IMB-1215, if you need it.
Additionally, there’s a PCIe x16 slot on the IMB-1215 which can be used for the choice of own graphics card or any other additional peripheral if you need this level of expansion.
The IMB-1215 is perfect for digital signage – even the manufacture of your own panel pc solution if you need to make your system more compact and slim-line!
- Socket LGA 1151 for Intel® Core i7/i5/i3/Celeron
- Supports Dual Channel DDR4 SO DIMM 2400/2666, up to 32GB
- 3 x Displayport, 1 x eDP
- 4 xUSB 3.1, 4 xUSB 2.0, 2 x SATA3, 4 x COM
- 1 x PCIe x16, 1 x M.2 Key E , 2 x M.2 Key M
- 1 x TPM
- 19V DC-in (DC Jack/4-pin ATX PWR Con) (Option: +19V~28V)
- Supports RAID function
No availability or pricing information is available at this moment. For specifications and further details visit: www.asrockind.com
