IMP34DT05 – MEMS audio sensor omnidirectional digital microphone
MEMS Microphone
The IMP34DT05 is an ultra-compact, low-power, omnidirectional, digital MEMS microphone built with a capacitive sensing element and an IC interface.The sensing element, capable of detecting acoustic waves, is manufactured using a specialized silicon micromachining process dedicated to producing audio sensors.
The IC interface is manufactured using a CMOS process that allows designing a dedicated circuit able to provide a digital signal externally in PDM format.
The IMP34DT05 is a low-distortion digital microphone with a 64 dB signal-to-noise ratio and –26 dBFS ±3 dB sensitivity.
The IMP34DT05 is available in a top-port, SMD-compliant, EMI-shielded package and is guaranteed to operate over an extended temperature range from -40 °C to +85 °C.
Key features
  • Single supply voltage
  • Low power consumption
  • AOP = 122.5 dBSPL
  • 64 dB signal-to-noise ratio
  • Omnidirectional sensitivity
  • –26 dBFS ±3 dB sensitivity
  • PDM output
  • SMD-compliant
more information: www.st.com
