With the gKINO-V1000 small series, ICP Germany strengthens its product portfolio in the Mini-ITX board area by two AMD® based solutions with RyzenTM CPUs.
The gKINO-V1605B board is equipped with the quad-core processor V1605B with 3.6GHz clock frequency, whereas the gKINO-V1202B is equipped with the dual-core processor V1202B with 3.2GHz processor clock. Common to both is the RadeonTM VEGA HD7000 graphics. It supports a resolution of 4K (3840×2160) on its four display port outputs. DX11, UVD3, H.264, VC-1, MPEG-2, DivX®, Open CLTM, OpenGL 4.2 and soon Open GL4.3. gKINO-V1000 series can be equipped with a maximum of 64GB ECC memory on the two 260 pin SODIMM slots.
The gKINO-V1000 series offers on the IO-Shield besides the four DP interfaces, two RJ45 GbE, two RS-232, two USB2.0, two USB 3.2 Gen1 with 5Gb/s and audio with 6 Watt amplifier circuit. Furthermore, two RS-232 with Cctalk, four RS-232, two USB 2.0, SATA 3.0 and 8-bit GPIO are available on pin header. Expansion cards can be operated on the PCI Express x16 and the M.2 2242/2280 slot with PCIEe x2 and SATA signal. To secure the system, the boards can be delivered equipped with a TPM 2.0 Nuvoton NPCT750AAAYX. The boards also have an intrusion detection pin and watchdog functionality. Both versions work reliably in a temperature range from -10 °C to 70 °C.
Upon customer request, ICP can also supply the two gKINO-V1000 boards as a bundle with processor, industrial RAM and storage media.
Specifications
- Mini-ITX Form Factor
- AMD® RyzenTM V1000 Embedded CPU
- Max. 64GB DDR4 SO-DIMM memory with ECC support
- Quadruple/4-fold 4K Display Support
- AMD RadeonTM GPU VEGA Graphics
- 1x M.2 2280, 1x PCIe x16
- GbE Ethernet, USB3.2, DP, RS-232
- Intrusion Detection, TPM, Cctalk, Watchdog
Applications
- Industrial PC Systems
- Compact PC Systems
- Image and video processing
- Panel PC and embedded systems
- Gaming
The gKINO-V1000 series appears to be available now from ICP Germany. More information may be found in ICP’s announcement.
