![Infineon CY8CKIT-062S2-AI PSoC 6 Edge AI Evaluation Kit is Built for Seamless AI Integration in Embedded Applications Infineon CY8CKIT-062S2-AI PSoC 6 Edge AI Evaluation Kit is Built for Seamless AI Integration in Embedded Applications](https://www.electronics-lab.com/wp-content/uploads/2024/07/CY8CKIT-062S2-AI_KIT.png_2013019694-e1721107248839.jpg)
Infineon CY8CKIT-062S2-AI Evaluation Kit is a Hardware platform focused on Machine Learning (ML). Built around the PSoC 6 family of MCUs this dev board includes sensors like radar, microphone, magnetometer, IMU, air pressure sensor, and much more. The board features Wi-Fi and Bluetooth for connectivity and includes an expansion header that can be used to connect other modules and sensors. These features make this board useful for applications like smart home automation, industrial monitoring, wearables, etc.
Previously we have written about similar AI and Machine learning-powered dev boards like the TIDEP-01004, the Avnet RASynBoard, the AISonic IA8201 feel free to check those boards out if you are interested in the topic.
Infineon CY8CKIT-062S2-AI Dev Board Specifications
- Microcontroller Unit (MCU)
- Infineon PSoC 62S2 MCU
- Dual-core Arm Cortex-M4F and Cortex-M0+
- Up to 1 MB Flash memory
- 288 KB SRAM
- Wireless Connectivity
- Murata Electronics LBEE5KL1YN-814 module
- Wi-Fi 4 (802.11b/g/n) with speeds up to 65Mbps
- Bluetooth 5.2 BR/EDR/LE with speeds up to 3Mbps
- Sensor Suite
- XENSIV 60 GHz radar sensor: presence detection, counting, tracking, gesture sensing, and motion detection
- XENSIV MEMS microphone: sound detection (e.g., siren, cough, snore, baby cry)
- DSP368 barometric pressure sensor
- BMI270 inertial measurement unit (IMU)
- PDM-PCM interface for additional microphones
- Interfaces
- USB Type-C for power and data transfer
- Two Pmod connectors for expansion
- Five CapSense buttons and two CapSense® sliders
- Arduino Uno R3 shield-compatible headers
- Security Features
- Hardware-based Root of Trust (RoT)
- Hardware cryptographic accelerators
- Secure onboarding, boot, key storage, and firmware updates
- Trusted firmware-M security services
- Debugging and Programming
- KitProg3 onboard debugger and programmer
- Dimensions: Not Mentioned
The evaluation kit includes pre-built machine-learning models for easier application development. It’s compatible with Infineon’s ModusToolbox software, a versatile embedded development tool used in the PSoC 64 IoT Security Workshop Development Kit. ModusToolbox supports machine learning, connectivity, and security and is compatible with Windows, Linux, and macOS. The board also supports the Imagimob Studio platform, simplifying the creation and deployment of machine-learning models on small devices like the PSoC 6 MCU.
The board also supports TensorFlow Lite Micro and neural network acceleration via CMSIS-DSP and CMSIS-NN. Combined with robust hardware and connectivity options such as MQTT, HTTP, and AbIROC Bluetooth, it facilitates rapid prototyping and the development of AI applications.
The Infineon CY8CKIT-062S2-AI Evaluation Kit is priced at $37.50 on Mouser Electronic and $50 on DigiKey.
by cnx-software
