![Infinite Noise true random number generator Infinite Noise true random number generator](https://www.electronics-lab.com/wp-content/uploads/2018/02/infinite-noise-prelaunch_jpg_project-main.jpg)
This is an Open hardware USB true random number generator coming soon on crowdsupply.com
The Infinite Noise TRNG is an affordable and secure true random number generator (TRNG) based on a modular entropy multiplier technique that continuously loops over previous random output, gathering randomness from the noise of the hardware components along the way, to generate the next random output. The simplicity of this technique makes it quite robust to common attacks like signal injection. The openness of the implementation makes it and easy to inspect and verify, as all security hardware should be!
Features & Specifications
- Default 30 KB/second of random data
- No firmware
- “Whitening” implemented in the driver
- Comes with polycarbonate enclosure
- Immune to power supply noise and RF interference
- Uses only stock components
- Health monitor built into host drivers
- Multiplatform driver support (Windows, Linux, and also ARM-support)
- Fully open source (see GitHub repo)
Login
