Intel RealSense D421 Depth Camera features Stereo Vision, 3D Scanning and AI Applications With D4 Vision Processor
Intel RealSense has recently introduced the Depth Camera Module D421, an entry-level stereo depth camera designed to make depth-sensing more accessible and affordable. It integrates the D4 Vision Processor and the optical module on a single board, allowing for onboard depth calculations, and making it highly efficient and space-saving. With a 75° × 50° field of view and a recommended range of 0.2 m to 3 m, it is ideal for 3D vision-based AI applications such as robotics, 3D scanning, and object recognition. It uses a 1MP global shutter for high-speed depth sensing and is compatible with popular operating systems like Windows, Linux, and Android, supported by the Intel RealSense SDK 2.0.
Lightweight and easy to integrate, the D421 is designed for indoor and outdoor use, offering high-depth accuracy, up to 1280 × 720 resolution, and up to 60 fps. Its compact form and USB-C connector make it a flexible tool for robotics, toys, 3D glasses, and consumer electronics. Therefore, they depend on quick, accurate depth measurements to move around, find things, and avoid obstacles.
Previously we have read about some similar Depth Camera modules including The E-Con Systems TOF Camera, the STMicroelectronics VL53L5 Mini Depth Camera, the Stereo vision Camera, the Arducam Kingkong, and many more. Feel free to check those out if you are interested in the topic.
Intel RealSense Depth Camera Module D421 Specifications:
- Processor: Intel D4 Vision Processor
- Depth Technology: Stereoscopic
- Image Sensor: 1MP global shutter depth sensors
- Depth Output Resolution: Up to 1280 × 720
- Minimum Depth Distance (Min-Z) at Max Resolution: ~20 cm
- Baseline: 50mm
- Depth Frame Rate: Up to 60 fps
- Field of View (FOV): 75° (H) ±3° × 50° (V) ±3°
- Recommended Depth Range: 0.2 meters to 3 meters (varies with lighting)
- Minimum Depth Distance (Min-Z): ~20 cm
- Depth Accuracy: < 4% at 2 meters
- Shutter Type: Global shutter
- Filter: IR Band Pass Filter
- Operating Temperature: 0°C to 35°C
- Form Factor: Camera module
- Dimensions: 95 mm × 32 mm × 10.18 mm
- Connectors: USB-C
- Platform Compatibility: Windows, Linux, Android
- SDK Support: Intel RealSense SDK 2.0 (Open source, platform independent)
- Use Environment: Indoor/Outdoor
Additionally, the SDK supports the Open3D library for 3D data processing, ROS/ROS2 for robotics, and TensorFlow and OpenVino for AI. You can download the SDK from here. Similarly, it includes C/C++ code samples from their GitHub repository, for RealSense cameras and offers wrappers for popular languages like Python, C#/.NET, and Matlab.
The Intel RealSense Depth Camera Module D421 is available for preorder on their official product page at $80.00. however, you have to buy a minimum 10 numbers of modules to get it at this price rate. You can find further information on Intel RealSense’s official website.
