iWave releases first Xilinx Zynq 7000 based SOM Module
The Zynq 7000 family based on the All Programmable SoC architecture are processor-center platforms that offer software, hardware and I/O programmability in a single chip.
iWave Systems which has released several Altera based FPGA system on modules has just announced its SODIMM (Small Outline Dual In-Line Memory Module) form-factor Xilinx Zynq based module known as the iWave’s iW-RainboW-G28M. The iW-RainboW-G28M features the Xilinx Zynq 7000 series SOC with Dual Cortex A9 CPU @ 866MHz, 85K FPGA logic cells, and up to 125 FPGA IOs.
iWave iW-RainboW-G28M SOM
The iWave iW-RainboW-G28M is compatible with the Zynq Z-7007S, Z-7014S, Z-7010, and Z-7020 SoC. Equipped with an onboard 512 Mbytes of NAND Flash, 512Mbytes of DDR3 SDRAM, Gigabit Ethernet, USB 2.0 ports, an optional Micro SD slot, and an optional WIFI/Bluetooth module with a form-factor of 67.6 mm x 37 mm plug-in SODIMM style. It supports -40 to 85oC temperatures and powered through the SOM edge connector with a 3.3 DC Volt.
SOM Block Diagram
The following are the SOM specifications:
  • SoC –
    • Xilinx Zyng 7000 SoC
    • Single/Dual Cortex A9 @ up to 866MHz
    • Up to 85K logic cells
  • SoC Compatibility –
    • Compatible with Z-7007S, Z-7014S, Z-7010, and Z-7020
  • Memory –
    • 512 MB DDR3 and expandable to 1GB
    • 512 MB NAND Flash
    • An Optional QSPI Flash
    • Optional Micro SD Slot/eMMC (Optional)
  • Zynq PS & PL Interfaces –
    • Gigabit Ethernet x1 Port
    • USB 2.0 OTG x 1 Port
    • SD (4bit) x 1 Port
    • Debug UART
    • JTAG Port
    • 60 LVDS/120 SE FPGA IOs
  • SOM Features –
    • PMIC with RTC
    • Gigabit Ethernet Transceiver
    • USB 2.0 Transceiver
    • Optional Wi-Fi and Bluetooth Module
  • OS Support –
    • PetaLinux 4.9.0
  • Power Supply –
    • 3V DC
  • Temperature Support –
    • -400C to +850C
  • Dimension –
    • 6mm x 37mm
The iW-RainboW-G28M has applications in the areas of Industrial Automation, Machine Vision, Control & Measurement, Scientific Instruments and Medical Instruments. For pricing and availability, please contact iWave directly iW-RainboW-G28M SODIMM SOM.
Hi, I'm software, a hardware guy, and a technical writer. Have had a stint with the EdTech industries, but mostly interested in the space of deploying AI for edge computing. Otherwise, I am writing or coding about some technology pieces covering IoT, GPU computing, LoraWAN, PCB, Machine Learning, Precision Agriculture, Open Electronics, and related fields. Got a tip, freebies, launch, gig or leak? Contact me on Twitter, or via email: charlesayibiowuAThotmail.com. I don't bite.
view all posts by ayo
