iWave Systems Introduces a SOM based on ZU19EG / ZU17EG / ZU11EG Xilinx ZynQ UltraScale+ MPSOC
iWave Systems introduces a powerful SOM (System on Module) with six heterogeneous ARM processor cores (four 64-bit ARM Cortex-A53 and two 32-bit ARM Cortex-R5 Cores), an ARM Mali-400 MP2 GPU, and a big chunk of the latest-generation UltraScale+ programmable logic cells scaling all the way to 1 million. Designed a ZU19EG / ZU17EG / ZU11EG Zynq UltraScale+ MPSoC System on Module in the package C1760 and a 10+ Years Longevity support.
The CPU module has a compact-size measuring 110mm by 75mm, equipped with ZU19/17/11 EG MPSoC, 64-Bit 4GB DDR4 for PS, dual 4GB DDR4 64-Bit for PL, 8GB eMMC (expandable up to 128GB) as well as integrated with Ethernet PHY, USB PHY, and power circuitry to provide control and processing capabilities as an embedded system. Besides these, all the FPGA IOs, 16 x PL-GTY @32.75Gbps, 32 x PL-GTH @16.3Gbps, 4 x PS-GTR @6Gbps Transceivers & FPGA IOs up to 48LVDS/96SE + 46SE IOs are terminated at high-speed Board-to-Board (B2B) connector.
Product Highlights:
It is ready to run Linux OS and targets a wide variety of applications like the High-Speed Networking using 25G, 40G & 100G Optical, Cloud Computing, 4K Video Surveillance System, Deep Neural AI/ML Networks, Automotive Imaging Radar, Intelligent Data Center, etc.,
Targeted Applications
iWave Systems has the stock of various ZU19EG / ZU17EG / ZU11EG MPSoC based SOMs which is ready for immediate dispatch
iWave Systems also offers a versatile iW-RainboW-G35D Development Board for evaluating the SOM Module. It takes full features of the Zynq UltraScale+ MPSoC device to have explored a robust set of peripherals such as Dual FMC for doing initial POC with the available off-the-shelf FMC boards, 12G SDI IN & OUT, SFP+, USB 3.0 Type C, Gigabit Ethernet, Dual PMOD, DisplayPort (DP), PCIe x4 interface, M.2 SATA interface, JTAG, CAN and so on. The iW-RainboW-G35D is a solid reference design for development based on Xilinx Zynq UltraScale+ MPSoC solutions.
More information about the new products can be found at:
- https://www.iwavesystems.com/zu19-17-11-zynqul-som.html
- https://www.iwavesystems.com/product/dev-kits/fpga/zu19-17-11-zynq-ul-dev-kit/zu19-17-11-zynq-ultrascale-mpsoc-devkit.html
For further information or enquiries please write to mktg@iwavesystems.com or contact our Regional Partners.
