![iWave Unveils STM32MP13x Solderable System on Module in OSM Size-0 Form Factor iWave Unveils STM32MP13x Solderable System on Module in OSM Size-0 Form Factor](https://www.electronics-lab.com/wp-content/uploads/2023/05/STM32MP13x-SoM-Banner-850x478.png)
In line with the new industry standard, Open Standard Module or OSM, defined by SGET, iWave announces the release of the iW-RainboW-G54S: STM32MP13x LGA System on Module (SoM). The SoM incorporates STM32MP13x MPU from STMicroelectronics and is built on OSM Size-0 standard, providing high performance, power efficiency, and a rich set of interfaces to meet versatile market needs.
High-end wearables and other low-powered embedded & consumer applications benefit from the new STM32MP13x MPUs featuring the ARM Cortex-A7 application processors running at 1GHz. Cortex-A7 has all the features of the high-performance Cortex-A15 and Cortex-A17 processors, including physical virtualization, NEON, and 128-bit AMBA 4 AXI bus interfaces.
Key features of STM32MP13x OSM System on Module
- STM32MP13x MPU with Arm Cortex-A7
- Up to 1GB DDR3L, 16Mb QSPI NOR Flash
- 1 x RGMII, 1 x USB 2.0 OTG, 1 x USB 2.0 Host
- 2 x SDMMC, 2 x ADC
- 4 x UART, 1 x Console UART, 2 x SPI, 2 x I2S, 2 x I2C
- 16 x OSM GPIOs
- Size-0 Form Factor: 30 mm x 15 mm
- Solderable LGA Package in OSM v1.1 Standard
- 188 Contacts
The STM32MP13x System on Module is built on a 30 mm x 15 mm OSM Size-0 standard, the smallest size in the OSM variants making it an ideal choice for building portable consumer products. The 188 LGA contacts available on its back for mating with the carrier board make the platform resistant to shock and vibrations, ensuring high levels of robustness.
iWave brings design compactness while enabling modularity and scalability to ST customers. To fulfill the ever-increasing need for rapid data transfer, the SoM supports dual USB 2.0 interfaces and Gigabit Ethernet delivering a robust, high-performance, consistent, high-quality user experience.
Key features of STM32MP13x Single Board Computer
- Up to 1GB DDR3L, 16Mb QSPI NOR Flash, 16Mb SPI NOR Flash
- Micro SD, M.2 connector Key B (USB, Nano SIM connector)
- Gigabit Ethernet (RGMII), USB 2.0 OTG, USB 2.0 Host
- RS232, CAN x1, GNSS receiver, RTC Battery
- 3.5mm Audio IN/OUT Jack, Speaker Header
- Expansion: CAN x1, SDMMC 8bit, SPIx1, PWM x1, ADC x2, UART x2
- DC 12V Input, -40°C to +85°C Industrial Grade
- 100 mm x 72 mm (Pico ITX Form Factor)
- Linux 5.15.67
The System on Module forms the building block for products and solutions that require a rich set of interfaces with high performance and efficiency. The SoM enables customers to shorten their time to market with reduced risk and complexity.
“STM32MP13x MPU incorporating Cortex-A7 offers power and performance balance for a variety of devices with varying requirements,” said Ahmed Shameem, Hardware Project Manager at iWave Systems. “The STM32MP13x Solderable System on Module leverages the processor features to provide rich performance for diverse low-power embedded applications that ST customers require.”
STM32MP13x OSM SoM is mounted on a carrier board as a Single Board Computer (SBC), which can also be used as an evaluation kit. This feature-rich multimedia insert-ready SBC is available in Pico-ITX form factor, ready to be integrated across diverse machine learning applications.
The System on Module and Single Board Computer are go-to-market and production ready complete with documentation, software drivers, and a board support package. iWave maintains a product longevity program that ensures that modules availability for long periods of time (10+ years).
More information on STM32MP13x OSM System on Module can be found here.
