![Khadas Mind Graphics eGPU features NVIDIA GeForce RTX 4060 Ti Khadas Mind Graphics eGPU features NVIDIA GeForce RTX 4060 Ti](https://www.electronics-lab.com/wp-content/uploads/2024/07/8cab1f_ad30bfc9c0ca44f7b4c6bb014e828547mv2-e1721391185760.webp)
Khadas has introduced the Mind Graphics eGPU, which features the NVIDIA GeForce NVIDIA Ti. This external GPU enhances performance for creative design, video rendering, and gaming. Key features include DLSS 3 technology for smoother frame rates, AV1 encoding for better video compression, and support for up to four screens through various ports including Thunderbolt 4/3 USB-C, HDMI 2.1a, and DisplayPort 1.4a. The eGPU is a versatile hub with a built-in microphone array, dual-driver speaker system, and 85W PD fast charging. Housed in a 2.5L Al-Si-Cu die-cast aluminum alloy chassis this can be used for applications like Creative Design, Gaming, Video Rendering, and much more.
Previously we have written about ADT-Link UT3G a USB4 to PCIe x16 eGPU adapter, which is a GPU adapter that costs only $129.0 and can hold an RTX4090, feel free to check that out if you are looking for something cheap and useful.
Khadas Mind Graphics eGPU Specifications
- Processor and GPU:
- NVIDIA GeForce RTX 4060 Ti Desktop GPU (8GB GDDR6)
- Mind Link Max Speed: 128 GT/s
- Memory and Storage:
- Not specified
- Display and Graphics:
- 2× HDMI 2.1a (Supports 4K/240Hz or 8K/60Hz)
- 1× DisplayPort 1.4a (Supports 4K/240Hz or 8K/60Hz)
- Audio:
- Built-in dual speaker system for an immersive audio experience
- 1× Headphone Jack 3.5mm with Mic support
- 1× Far-field Microphone Array
- Connectivity:
- 1× USB-C (Supports USB4/ThunderBolt4/ThunderBolt3)
- 3× USB-A 3.2 Gen 2 (10Gbps)
- 1× Ethernet (2.5Gbps)
- 1× SD Card 4.0 (200MB/s)
- 1× Mind Link
- Enclosure:
- CNC unibody aluminum enclosure
- Security:
- Millisecond fingerprint registration and login
- Power:
- Not specified
- Miscellaneous:
- 1× Speaker
The Mind Graphics eGPU Module integrates a microphone array, dual-driver speaker system, and 85W PD fast charging, streamlining setup by combining GPU performance and device charging into one solution. Khadas emphasizes the 2.5L chassis made from Al-Si-Cu die-cast aluminum alloy, offering durability and a premium look.
Khadas Mind Graphics eGPU costs only $999 and is available on Khadas shop now, you can also purchase it from Amazon from August 1st. Includes everything you need.
