Kyocera AVX PrizmaCap™ Capacitors use an activated carbon electrode and have a propylene carbonate-based (PC) electrolyte with a paper separator and SMT leads. The PrizmaCap current collector is made of a special low ESR-type aluminum. The PrizmaCap features a cell voltage of ~2.1V/cell and 2.1V rated voltage. Kyocera AVX PrizmaCap Capacitors offer a low-profile product with high energy, low ESR and LC, and high-temperature capabilities with an operating temperature range of -55°C to +90°C.
- Low profile
- Larger capacitance in prismatic form factor
- High temperature
- Lightweight design
- RoHS compliant
- Lead-free
Applications
- Wearables
- Handhelds
- High-temperature industrial
- BLUETOOTH® keyboard
- Battery assist
- Power peripherals
- Tables/E-reader
- High reliability
- Space-constrained designs
Specifications
- 2.16A to 8.63A peak current range
- 110mΩ ESR max. at 1kHz
- 3.5F to 15F rated capacitance range
- 2.1V rated voltage
- 0.5mm minimum height
- -55°C to +90°C operating temperature
more information: https://www.kyocera-avx.com/products/supercapacitors/prizmacap-scp-series/
Login
