![Laird Sentrius™ MG100 micro-gateway with LTE-M/NB-IoT and Bluetooth 5 Laird Sentrius™ MG100 micro-gateway with LTE-M/NB-IoT and Bluetooth 5](https://www.electronics-lab.com/wp-content/uploads/2020/10/LairdSentrius™MG100.jpg)
Laird has introduced Sentrius™ MG100 micro-gateway with LTE-M/NB-IoT and Bluetooth 5
Based on Laird Connectivity’s Pinnacle 100 modem, the Sentrius MG100 Gateway captures data from Bluetooth 5 sensors and sends it to the cloud via a global low power cellular (LTE-M/NB-IoT) connection. Supports LTE bands 1, 2, 3, 4, 8, 12, 13, 20, and 28.Based on the Sierra Wireless HL7800 module, the MG100 includes Bluetooth 5 features like CODED PHY, 2M PHY, and LE Advertising extensions.
Key features
- Wireless connectivity
- Flexible power options
- Certified for global deployment
- Antenna choices
Additional features
- LTE-M / NB-IoT radio via Sierra Wireless HL7800 module (Chipset: Altair ALT1250)
- LTE bands 1, 2, 3, 4, 8, 12, 13, 20, 28
- Nordic nRF52840 – BT v5, Coded PHY (Long range), 1MPHY & 2MPHY support
- Onboard Cortex-M4F Microcontroller:
- 32-bit @ 64 MHz, 256 KB of RAM, 1 MB internal flash, 8 MB QSPI
- Certifications:
- FCC, IC, CE, BT SIG plus PTCRB, GCF, and End Device certified
- AT&T, Verizon, Vodafone (all pending)
- Flexible Programming:
- Hostless mode via Zephyr RTOS
- Secure Firmware Upgrade:
- Comes pre-programmed with Laird Connectivity’s secure bootloader
- Antenna Options:
- Unique integrated antenna variant plus external variant with SMA connectors
- Compact form-factor:
- 110.28 x 99.16 x 35.32 mm
- Custom branding, packaging, application development, all available
more information: https://www.avnet.com/shop/emea/products/laird-connectivity/450-00011-k1-3074457345643563816/
Login
