Laser Diode Driver project will help you safely drive (constant current) a 3 mW visible Laser Diode for your application.
- Input supply – 2.5 to 6 VDC
- Onboard preset to adjust the current flow to the Laser Diode
- Power-On LED indicator
- Header connector for easy input supply and LASER DIODE module connection
- Laser diode is not included
- Circuit is designed around Sanyo DL3148-025 LASER DIODE
- PCB dimensions 37 mm x 42 mm
Laser Diode Driver – [Link]
Login
