![Latest Solutions from CUI & Digi-Key by OEMSecrets.com Latest Solutions from CUI & Digi-Key by OEMSecrets.com](https://www.electronics-lab.com/wp-content/uploads/2019/01/Compare-Electronic-Component-Prices-Inventory-OEMsecrets.png)
Interconnect Solutions
CUI’s screw type terminal block connectors offer wire gauges ranging from 26 AWG to 10 AWG and horizontal, vertical, and 45° orientations. With operating temperature ranges from -40°C to +105°C and 5 mm, 5.08 mm, and 7.62 mm pitches, CUI’s low cost screw type terminal blocks are well suited for a range of interconnect needs. Learn More ►
Conforming to the 3.5 mm audio standard, CUI’s waterproof audio jack connectors carry Ingress Protection (IP) ratings of IP67 to deal with the harsh conditions found in industrial and outdoor applications. The models are available in surface mount, mid mount SMT, and through hole mounting styles with 12 VDC rated operation, 1 A current ratings, and profiles as low as 5.6 mm. Learn More ►
Audio Solutions
CUI’s waterproof speakers, microphones and buzzers offer Ingress Protection (IP) ratings up to IP68, diameters as small as 4 mm, and depths as low as 1.5 mm. With a multitude of configurations and options, these IP rated audio solutions deliver the durability and performance needed to withstand harsh, high moisture environments. Learn More ►
CUI’s MEMS microphones provide users with improved audio quality and performance in compact, low profile packages as small as 2.75 mm x 1.85 mm x 0.95 mm. Featuring sensitivity ratings from -44 dB up to -26 dB, signal to noise ratios from 57 dBA up to 65 dBA, and sensitivity tolerances as low as ±1 dB, these MEMS microphones are ideal for a range of portable consumer electronics applications. Learn More ►
Power Solutions
Encapsulated AC-DC Power Supplies from 2 W – 25 W
With compact footprints and 4 kVAC isolation, CUI’s PSK series of encapsulated AC-DC power supplies from 2 W to 25 W are housed in board-mount, chassis-mount, wire-lead, and DIN rail packages. The modules operate at temperature ranges of -40°C up to +85°C at full load, making them ideal for a range of space-constrained applications. Learn More ►
10 W Isolated DC-DC Converters
Outputting up to 10 W of continuous power, CUI’s range of open frame and encapsulated PYBJ10 isolated DC-DC converters deliver a 4:1 input voltage range and up to 88% efficiency. Ideal for convection-cooled equipment and a range of other applications, CUI’s PYBJ10 series features a -40°C to +85°C operating temperature range with over voltage, over current, and short circuit protections. Learn More ►
Thermal Management
DC Axial Fans with omniCOOL™ System
CUI’s CFM-V series of high-performance axial fans deliver superior forced air cooling performance and longer operational life compared to traditional sleeve bearing designs thanks to their innovative omniCOOL system. With airflows ranging from 5.4 CFM in the 40 mm series up to 138 CFM in the 120 mm series, these DC axial fans feature noise levels from 10.7 dB to 48 dB, making them ideal for a variety of IT and telecommunication equipment, medical devices, and industrial applications. Learn More ►
High Performance Peltier Modules with arcTEC™ Structure
CUI’s line of high-performance thermoelectric modules delivers superior cooling performance and a longer cycle life with its innovative arcTEC structure. Ranging in size from 20 mm to 50 mm with profiles as low as 3.15 mm, these Peltier modules are available with a ΔTMAX up to 95°C (Th=50°C) and current ratings from 2.0 A to 12.5 A. Learn More ►
