Lattice MachXO5D-NX FPGA Family: Enabling Hardware Security in Programmable FPGAs
1.059
Lattice Semiconductor has introduced the MachXO5D-NX FPGA family, which integrates a hardware root of trust (RoT) into low-power FPGAs to address security challenges. By combining on-chip Flash memory and hardware encryption, these FPGAs minimize code capture risks during load time. The MachXO5D-NX family includes three variants with logic cell counts of 27k (FMXO5-25), 53k (LFMXO5-55T), and 96k (LFMXO5-100T).
These FPGAs feature built-in hardware encryption, a cryptographic engine supporting AES-256, ECDSA-384/521, SHA2-256/384/512, and RSA 3072/4096, and a unique secret identity (USID) for device identity protection. Built on a 28-nm fully-depleted silicon-on-insulator (FD-SOI) process, these FPGAs reduce power consumption by 75% and lower soft error rates by 100x. They support interfaces such as MIPI D-PHY (CSI-2, DSI), LVDS, Gigabit Ethernet, and PCIe, making them suitable for secure edge applications.
Top & Bottom View
Top & Bottom View
Specifications of Lattice MachXO5D-NX FPGA Family
  • FPGA: Lattice Semi MachXO5D-NX FPGA family
    • 27k (FMXO5-25)
    • 53k (LFMXO5-55T)
    • 96k (LFMXO5-100T)
  • Programmable Logic: 27k to 96k logic cells, 20 to 156 multipliers
  • Memory:
    • 1.9 Mbit to 7.3 Mbit embedded memory
    • DDR3/DDR3L/LPDDR4 support
  • Interfaces:
    • MIPI D-PHY, LVDS, SLVS, SGMII
    • PCIe Gen1/2, Ethernet
  • I/O:
    • 200-300 programmable I/O
    • High-performance (1.8V) and wide-range (3.3V)
  • Analog Features:
    • Dual ADC (1 MSPS, 12-bit SAR)
    • Three continuous-time comparators
  • Security Features:
    • Bitstream encryption (AES-256)
    • Authentication (ECDSA)
    • Secure boot
  • Additional Features:
    • Clock Data Recovery (CDR)
    • sysDSP blocks with Dynamic Shift for AI/ML
    • sysMEM EBR
    • Soft error mitigation
    • Dual ADC, dual DAC
  • Power Management: Low-power and high-performance modes
  • Dimensions: 17 x 17mm
For more detailed information, you can check out the MachXO5-NX Family datasheet on Lattice Semiconductor’s website.
The MachXO5-NX FPGAs enable edge AI and math-intensive applications with multipliers and DSP cells. The FPGA also comes with MIPI, LVDS, Ethernet, PCIe, and DDR interfaces. Embedded Flash memory supports multi-boot and user storage. Additionally, the chips are compatible with the Lattice Radiant design suite and utilize pre-engineered IP modules.
This FPGA also features a hardware-based cryptographic engine with advanced encryption standards (AES), a true random number generator, and a unique secret identity for enhanced security. The devices are crypto-agile, which means they can switch between multiple cryptographic algorithms or methodologies. Additionally, they support Commercial National Security Algorithms (CNSA) specified for bitstream and cryptographic algorithms like AES-256 and SHA2-512. By integrating security features into hardware, no FPGA fabric needs to be dedicated to security, ensuring efficient utilization of resources.
The MachXO5-NX includes an FD-SOI’s layered architecture that reduces leakage current, resulting in 75% lower power consumption and a 100x reduction in soft errors. This makes it suitable for use in electrically noisy and radiation-prone environments.
Another problem this chip solves is the code capture risk, often associated with glitching—a process where a chip is powered with an electrical pulse or voltage fluctuation, causing temporary malfunction and potential security bypass. The MachXO5D-NX FPGAs help prevent unauthorized access and code capture by providing robust hardware-based protection.
Lattice Semiconductor also offers the MachXO5-NX development board, built around the MachXO5-NX-25 FPGA. This board provides a range of features for secure control and system management. It offers flexible I/O options, including SGMII and ADC, and is compatible with various expansion headers like Arduino, Raspberry Pi, and FX12. It supports multiple configuration modes (JTAG, I2C/I3C, SPI) and includes components like HyperRAM, LEDs, switches, and buttons for demonstration and prototyping purposes. The board is designed to simplify the development process and enhance security in programmable FPGA applications.
