LED-Tester-ready.jpg - Electronics-Lab.com
15
LED Tester with LCD Display
David @ robotroom.com build a microcontroller based LED tester with LCD display that shows the LED voltage, the current limit in mA, the desired led voltage and the calculated resistor value. The LED tester is based on ATtiny84 mcu which performs all the measurements and calculations and updates... Read More
