Lilygo T-Embed CC1101 Sub-GHz Transceiver Module with ESP32-S3 and TFT Display
1.360
Lilygo has recently launched the T-Embed CC1101, a transceiver module that integrates an ESP32-S3 dual-core LX7 microprocessor and a built-in Sub-GHz module based on the CC1101 chip, designed for communication in the 300-348 MHz, 387-464 MHz, and 779-928 MHz frequency bands. It features a 16MB flash memory, 8MB RSRAM, and supports wireless communication via Wi-Fi 802.11 b/g/n and BLE 5. The module is programmable through platforms like Arduino IDE and ESP-IDF and includes a 1.9-inch IPS colour TFT LCD with a 170×320 resolution powered by an ST7789V driver chip. Additionally, it has onboard functions like reset and boot buttons, IR transmit/receive capabilities, and battery voltage detection via IO04.
Previously we have covered some similar transceiver modules including the Miromico’s 2.4 Ghz Lora transceiver module, the LMD-401 Radio transceiver module, the Enocean Wireless transceiver module, and many more. Feel free to check those out if you are interested in this topic.
Lilygo T-Embed CC1101 Transceiver Module Specifications:
  • Microcontroller: ESP32-S3 Dual-core LX7 microprocessor
  • Flash: 16MB
  • SRAM: 8MB
  • Wireless:
    • Wi-Fi 802.11 b/g/n
    • Bluetooth 5 (BLE)
  • Sub-GHz Transceiver: CC1101 chip with frequency support in:
    • 300-348 MHz
    • 387-464 MHz
    • 779-928 MHz
  • Display:
    • 1.9-inch ST7789V IPS color TFT LCD
    • Resolution: 170(H)RGB x 320(V)
    • Interface: SPI
    • Drive Chip: ST7789V
  • Buttons:
    • Reset
    • Boot
  • I/O:
    • SPI interface for display
    • various GPIOs for other functions
  • Onboard features:
    • IR Transmit & Receive
    • Battery voltage detection (IO04)
  • Programming support:
    • Arduino IDE
    • ESP-IDF
  • Mislenious:
    • 1x MicroSD card Slot
    • Microphone
    • IR blaster
    • Speaker slot
    • 8XAPA102 RGB
    • JST GH 1.25mm
  • Power:
    • Onboard 1300mAh Li-Po battery
    • Input voltage by USB
  • Dimensions: [Not specified]
LILYGO’s T-Embed CC1101 Pin Diagram
Additionally, this board also includes an infrared transmitter and receiver, a built-in microphone, and a PN532 NFC/RFID transceiver for contactless communication at 13.56 MHz. For extra I/O options, it has two Qwiic connectors, an encoder for menu navigation, and a MicroSD card slot for expanded storage. An onboard radio antenna enables reliable long-range communication, and the board can support external radio modules for more sub-GHz applications. The board supports both USB and Li-Po power, with a built-in 1300mAh Li-Po battery for extended operation in remote sensor applications.
T-Embed CC1101 Peripherals
The Lilygo T-Embed CC1101 is available for purchase on the company’s online store for $30.68. It is also available on Alibaba for $52.10. However, the shipping fee for one piece is $6.36.
About Sayantan Nandy
view all posts by sayantan
