![LM4040 Shunt Voltage Reference is very stable over different conditions LM4040 Shunt Voltage Reference is very stable over different conditions](https://www.electronics-lab.com/wp-content/uploads/2022/04/dbz0003a.png-large.png)
STMicroelectronics’ LM4040 is low power and high accuracy shunt voltage reference providing a stable output voltage over the industrial temperature range (-40°C to +125°C), with a maximum temperature coefficient of 70 ppm/°C. It is available in 0.1%, 0.2%, 0.5%, and 1% initial accuracy versions. The SOT323- 5L and SOT23-3L packages can be designed in applications where saving space is a critical issue. The very low operating current is a key advantage for power restricted designs. The LM4040 is very stable and can be used in a broad range of application conditions.
- Fixed 2.048 V, 2.5 V, 3.0 V, 4.096 V, and 5.0 V output voltages
- Ultra-low operating current: 10 µA at +25°C
- High precision at +25°C: ±0.1% (LM4040A), ±0.2% (LM4040B), ±0.5 % (LM4040C), ±1% (LM4040D)
- Very low LF noise: typ. 10 µ VP-P
- Stable when used with capacitive loads
- Industrial (-40°C to +125°C) temperature range
- 70 ppm/°C max. temperature coefficient
- Available in SOT23-3L and SOT323-5L packages
more information: https://www.ti.com/product/LM4040
Login
