![LT3091 – –36V, 1.5A Negative Linear Regulator with Programmable Current Limit LT3091 – –36V, 1.5A Negative Linear Regulator with Programmable Current Limit](https://www.electronics-lab.com/wp-content/uploads/2015/09/3091-1024x731.jpg)
The LT®3091 is a 1.5A, low dropout negative linear regulator that is easily paralleled to increase output current or spread heat on surface mounted boards. Designed with a precision current reference followed by a high performance rail-to-rail voltage buffer, this regulator finds use in applications requiring precision output, high current with no heat sink, output adjustability to zero and low dropout voltage. The device can also be configured as a 3-terminal floating regulator.
LT3091 – –36V, 1.5A Negative Linear Regulator with Programmable Current Limit – [Link]
Login
