LT3091 – –36V, 1.5A Negative Linear Regulator with Programmable Current Limit
Linear Technology Corporation announces the LT3091, the latest addition to our LDO+ family, a 1.5 A low dropout negative linear regulator featuring low noise, rail-to-rail operation, precision programmable current limit and a bidirectional output current monitor. The device is cable-drop compensation capable, easily paralleled for higher current or circuit board heat spreading, and configurable as a 3-terminal floating regulator. The LT3091’s input voltage range is –1.5 V to –36 V. A single resistor programs the adjustable rail-to-rail output voltage from 0 V to –32 V and dropout voltage is only 300 mV (typical at full load).
LT3091 – –36V, 1.5A Negative Linear Regulator with Programmable Current Limit – [Link]
Login
