![LT6658 – Precision Dual Output, High Current, Low Noise, Voltage Reference LT6658 – Precision Dual Output, High Current, Low Noise, Voltage Reference](https://www.electronics-lab.com/wp-content/uploads/2016/11/161103edne-linear-a-lt6658_col.jpg)
Linear Technology announces the LT6658, a precision voltage reference that incorporates two high current output buffers.
The LT®6658 precision 2.5V dual output reference combines the performance of a low drift low noise reference and a linear regulator. Both outputs are ideal for driving the precision reference inputs of high resolution ADCs and DACs, even with heavy loading while simultaneously acting as output supplies powering microcontrollers and other supporting devices. Both outputs have the same precision specifications and track each other over temperature and load. Both outputs are nominally 2.5V, however each can be configured with external resistors to give an output voltage up to 6V.
LT6658 – Precision Dual Output, High Current, Low Noise, Voltage Reference – [Link]
