![LT8390 – 60V Synchronous 4-Switch Buck-Boost Controller with Spread Spectrum LT8390 – 60V Synchronous 4-Switch Buck-Boost Controller with Spread Spectrum](https://www.electronics-lab.com/wp-content/uploads/2016/12/insider79-feature-image.jpg)
The LT8390, is a synchronous buck-boost DC/DC controller that can regulate output voltage, and input or output current from input voltages above, below and equal to the output voltage. Its 4V to 60V input voltage range and 0V to 60V output voltage range are ideal for voltage regulator, battery and supercap charger applications in automotive, industrial, telecom and even battery-powered systems. The LT8390’s 4-switch buck-boost controller, combined with 4 external N-channel MOSFETs, can deliver from 10W to over 400W of power with efficiencies up to 98%. Its buck-boost capability is ideal for applications such as automotive, where the input voltage can vary dramatically during stop/start, cold crank and load dump conditions. Transitions between buck, buck-boost and boost operating modes are seamless, offering a well regulated output even with wide variations of supply voltage. The LT8390 is offered in either a 28-lead 4mm x 5mm QFN or thermally enhanced TSSOP to provide a very compact solution footprint. [source]
LT8390 – 60V Synchronous 4-Switch Buck-Boost Controller with Spread Spectrum – [Link]
