![LTC2063 – 2μA Supply Current, Zero-Drift Operational Amplifier LTC2063 – 2μA Supply Current, Zero-Drift Operational Amplifier](https://www.electronics-lab.com/wp-content/uploads/2017/06/LTC2063.jpg)
The LTC2063 is a single low power, zero-drift, 20kHz amplifier. The LTC2063 enables high resolution measurement at extremely low power levels. Typical supply current is 1.4μA with a maximum of 2μA. The available shutdown mode has been optimized to minimize power consumption in duty-cycled applications and features low charge loss during power-up, reducing total system power.
The LTC2063’s self-calibrating circuitry results in very low input offset (5μV max) and offset drift (0.02μV/°C). The maximum input bias current is only 20pA and does not exceed 100pA over the full specified temperature range. With its ultralow quiescent current and outstanding precision, the LTC2063 can serve as a signal chain building block in portable, energy harvesting and wireless sensor applications.
LTC2063 – 2μA Supply Current, Zero-Drift Operational Amplifier – [Link]
