![LTC4282 – High Current Hot Swap Controller with I2C Compatible Monitoring LTC4282 – High Current Hot Swap Controller with I2C Compatible Monitoring](https://www.electronics-lab.com/wp-content/uploads/2015/10/4282.jpg)
The LTC4282 is an energy monitoring Hot Swap controller with dual MOSFET drive to enable 100A and higher current board designs. The LTC4282 ensures safe board insertion and removal from live 2.9V to 33V backplanes by controlling external Nchannel MOSFETs to gently power up capacitors, avoiding sparks, connector damage and system glitches. High current hot-pluggable boards utilize parallel MOSFETs to reduce voltage drop, but all of these MOSFETs require large safe operating area (SOA) to ride through overcurrent faults. By controlling two matching current limited paths, the LTC4282 halves each path’s SOA requirements, reducing MOSFET costs in high current applications (>50A). The LTC4282 provides a rugged, compact solution for hot plugging and monitoring, especially in high power circuit boards in servers, network routers and switches, and enterprise data storage systems.
LTC4282 – High Current Hot Swap Controller with I2C Compatible Monitoring – [Link]
