![MaaXBoard Nano is a i.MX8M SBC in Raspberry Pi-like style MaaXBoard Nano is a i.MX8M SBC in Raspberry Pi-like style](https://www.electronics-lab.com/wp-content/uploads/2021/02/MaaXBoard-Nano-SBC.jpg)
The MaaXBoard Nano is a low-cost, NXP i.MX 8M Nano processor-based, single-board computer ideal for embedded computing and smart edge IoT applications. The i.MX 8M Nano family of application processors is based on the Arm® Cortex®-A53 and Cortex-M7 cores which provide industry-leading audio, voice, and video processing for applications that scale from consumer home audio to industrial building automation and embedded computers. The MaaXBoard Nano is production-ready, FCC, CE, and RoHS certified. It is available in quantities of five hundred or greater.
The MaaXBoard Nano contains everything necessary to support and create Linux, Android or other OS-based systems. The platform offers several onboard peripherals including 1 GB of DDR4 memory, a Gigabit Ethernet port, quad USB 2.0 host ports, MIPI-DSI, MIPI-CSI, WiFi, Bluetooth, MicroSD card slot, four onboard microphones and an audio jack. A Raspberry Pi hat-compatible expansion connector also provides interfaces for UART, SPI, I2C and GPIO. These combined capabilities make it an ideal platform for investigating AI, IOT and multimedia applications.
Feature list
Processor
- NXP i.MX 8M Nano Processor
- Quad Arm CortexA53 @1.5GHz
- Single CortexM7F @750MHz
Memory
- 1GB DDR4 SDRAM
- 256mB QSPI Flash
- MicroSD Slot
- Supports 16GB eMMC
Communications and User Interface
- Gigabit Ethernet
- Quad USB2.0 Host
- MIPIDSI Display Interface
- MIPICSI Camera Interface
- WiFi 802.11 b/g/n/ac
- Bluetooth 4.2 and 5
- External Antenna Connector
- Four onboard Microphones
- Audio Jack
User I/O
- 40 Pin Low Speed Expansion Interface
- Raspberry Pi Hat Compatible
- Digital I/O voltage: 3.3V
- 3 X User Buttons
- 2 X User Leds
Other
- PMIC
- Type C 5V/3A Power input
- Operating Temperature: 0~70°C
Mechanical
- 85mm x 56mm form factor
Each MaaXBoard Nano is shipped with a quick start guide to assist developers with their hardware or software development project. A user-supplied 5V/3A USB Type C power supply is required to power the board. A 16 GB microSD card and a UART USB Serial translator are recommended for booting the MaaXBoard Nano out-of-box experience. To jump-start your development, Avnet offers supported Android 9.0 and Linux images available for download. For software debugging, an optional Microchip USB-to-UART evaluation board is recommended, allowing USB terminal access through a UART port on the 40-pin expansion connector.
Block Diagram
To purchase this kit, visit Avnet.me/MaaXBoard-Na
