![Mango: A Compact Size FPGA Research Platform Mango: A Compact Size FPGA Research Platform](https://www.electronics-lab.com/wp-content/uploads/2015/11/mango.png)
An arduino-compatible FPGA platform that can be used for a wide range of applications.
The Mango is a compact field-programmable-gate-array (FPGA) platform that can be used for a wide range of projects, such as signal processing, mobile computing and robotics.
FPGA Mango board comes with a soft-core Nios II processor running on an Altera Cyclone IV FPGA. The board comes with 16MB of SDRAM, 16Mb EPCS flash memory, and a micro SD card slot. The FPGA Mango board also comes equipped with 9 degrees of freedom IMU (with temperature sensor) and four PWM motor controllers, which makes it a perfect solution for many applications, including robotic applications.
Mango: A Compact Size FPGA Research Platform – [Link]
Login
