![MAX16126/MAX16127 – protect power-supply inputs from automotive voltage transients MAX16126/MAX16127 – protect power-supply inputs from automotive voltage transients](https://www.electronics-lab.com/wp-content/uploads/2019/04/MAX16126-MAX16127.png)
MAX16126/MAX16127 – protect power-supply inputs from automotive voltage transients, including load dump
The MAX16126/MAX16127 load-dump/reverse-voltage protection circuits protect power supplies from damaging input voltage conditions, including overvoltage, reverse-voltage, and high-voltage transient pulses. Using a built-in charge pump, the devices control two external back-to-back n-channel MOSFETs that turn off and isolate downstream power supplies during damaging input conditions, such as an automotive load-dump pulse or a reverse-battery condition. Operation is guaranteed down to 3V to ensure proper operation during automotive cold-crank conditions. These devices feature a flag output (active-low FLAG) that asserts during fault conditions.
For reverse-voltage protection, external back-to-back MOSFETs outperform the traditional reverse-battery diode, minimizing the voltage drop and power dissipation during normal operation.
The MAX16126/MAX16127 use external resistors to adjust the overvoltage and undervoltage comparator thresholds for maximum flexibility.
The MAX16127 provides limiter-mode fault management for overvoltage and thermal shutdown conditions; whereas the MAX16126 provides switch-mode fault management for overvoltage and thermal shutdown conditions. In the limiter mode, the output voltage is limited and active-low FLAG is asserted low during a fault. In the switch mode, the external MOSFETs are switched off and active-low FLAG is asserted low after a fault. The switch mode is available in four options: latch mode, 1 autoretry mode, 3 autoretry mode, and always autoretry mode.
The MAX16126/MAX16127 are available in 12-pin TQFN packages. These devices operate over the automotive temperature range (-40°C to +125°C).
Key features
- Increases Protection of Sensitive Electronic Components in Harsh Environments
- -36V to +90V Wide Input-Voltage Protection Range
- Fast Gate Shutoff During Fault Conditions with Complete Load Isolation
- Thermal-Shutdown Protection
- Active-Low FLAG Output Identifies Fault Condition
- AEC-Q100 Automotive Qualified
- Operates Down to +3V, Riding Out Cold-Crank Conditions
- -40°C to +125°C Operating Temperature Range
- Integration Reduces Solution Size
- Internal Charge-Pump Circuit Enhances External n-Channel MOSFETs
- Adjustable Undervoltage/Overvoltage Thresholds
- 3mm x 3mm, 12-Pin TQFN Package
- Reduced Power Dissipation Compared to Discrete Solutions
- Minimal Operating Voltage Drop for Reverse- Voltage Protection
- 350µA (max) Supply Current and 100µA (max) Shutdown Current at 30V Input
Applications
- Automotive
- Avionics
- Industrial
- Telecom/Server/Networking
Block Diagram
more information here: www.maximintegrated.com
