![MAX33012E Robust CAN Transceiver with ±65 V Fault Protection, Detection, and Reporting MAX33012E Robust CAN Transceiver with ±65 V Fault Protection, Detection, and Reporting](https://www.electronics-lab.com/wp-content/uploads/2021/03/Maxim_Integrated_MAX33012EASA_CAN_Transceiver_5Mbps_CAN_8_Pin_SO_RS_Components.png)
Maxim’s MAX33012E offers +5 V, 5 Mbps, diagnostics, and ±40 kV ESD protection
Maxim’s MAX33012E is part of a family of +5 V CAN (control area network) transceivers with integrated protection for industrial applications. It is equipped with extended ±65 V fault protection on the CAN bus for applications where overvoltage protection is necessary. The CAN family also incorporates high ±45 kV ESD HBM (human body model) protection and an input CMR (common-mode range) of ±25 V, exceeding ISO11898 specification of -2 V to +7 V. It is suited for applications where ground planes from different systems are shifting relative to each other.
- ±45 kV ESD HBM
- Input CMR of ±25 V
- Operating temperature range -40°C to +125°C
more information: https://www.maximintegrated.com/en/products/interface/transceivers/MAX33012E.html
Login
