MAX40108 1V, Low-Power, Precision Operational Amplifier
Maxim Integrated’s MAX40108 tiny, low-power, high-precision op-amp operates with a power supply voltage as low as 0.9 V
Maxim Integrated’s MAX40108 is a low-power, high-precision operational amplifier (op amp) that operates with a power supply voltage as low as 0.9 V up to 3.6 V. It is specified over the -40°C to +125°C extended operating temperature range. Available in a space-saving 1.22 mm x 0.92 mm 6-bump wafer-level package (WLP) with a 0.4 mm bump pitch, it is designed for use in portable, consumer, medical, and industrial applications.
MAX40108EVKIT Evaluation Board
  • Supply voltage range: 0.9 V to 3.6 V
  • Low 25.5 μA quiescent current
  • Internal EMI rejection
  • 168 kHz GBW
  • Low input bias current
  • Power-saving shutdown mode
  • Available in tiny, 1.22 mm x 0.92 mm, 6-bump WLP and 8-pin TDFN
Applications
  • Wearable devices
  • Home medical (blood glucose, weight scales, blood pressure, EKGs)
  • Fitness and health (smartwatches, heart-rate monitors)
  • Industrial IoT (pressure, flow, level, temperature, and proximity)
more information: https://www.maximintegrated.com/en/products/analog/amplifiers/MAX40108.html
