![Meadow: Full-stack .NET Standard IoT platform Meadow: Full-stack .NET Standard IoT platform](https://www.electronics-lab.com/wp-content/uploads/2018/10/Meadow.png)
The power of Raspberry Pi in the computing factor of an Arduino, and the manageability of a mobile app.
Meadow is a full-stack IoT platform. Out of the box, it gives you everything you need to build sophisticated IoT solutions with very little effort. From sensors to displays, it has you covered with curated drivers that are designed out of the gate to work with each other. And forget about having to fight with low-level hardware code; if you need to create a new driver, Meadow comes with protocol abstractions and a driver framework that make adding new peripherals a breeze.
Meadow and Meadow F7 are now live on Kickstarter.
Meadow: Full-stack .NET Standard IoT platform – [Link]
Login
