![Meduino Mega2560 Pro Mini Board Meduino Mega2560 Pro Mini Board](https://www.electronics-lab.com/wp-content/uploads/2017/12/Meduino_Mega2560_Pro_Mini_1.jpg)
This Arduino board called Mega2560 uses the ATmega2560 microcontroller and is offered in a reasonable price. The microcontroller used has 16 analog inputs, 54 digital IOs and is working on 5V voltage. Epalsite electronics designed the small board exactly for this microcontroller. You can buy it e.g. on ebay.com for 12.99 USD.
Specification of ATmega2560:
- DC Current per I/O Pin – 40 mA
- DC Current for 3.3V Pin – 50 mA
- Flash Memory – 256 KB of which 8 KB used by bootloader
- SRAM – 8 KB
- EEPROM – 4 KB
- Clock Speed – 16 MHz
Meduino ATmega2560 Pro Mini Specs:
- Completely compatible with original Arduino Mega2560
- Pin pitch: 0.1 inch
- Size: 5.42cm*3.68cm
- With Atmega16U2 chip as the USB to Serial converter
- Working voltage: 5V
- Input Voltage: 7-12V
- Analog Input Pins: 16
- Digital I/O pins: 54
- The maximal current from 3.3V regulator: 150 mA
Login
