Mekotronics R57 is A Rockchip RK3576 Powred fanless mini PC with dual GbE Ethernet and 6 TOPS AI Power
1.151
Mekotronics R57 is a fanless AI mini-PC powered by a Rockchip RK3576 octa-core Cortex-A72/A53 SoC SoC. Other than that it has dual GbE Ethernet, 6 TOPS NPU RS232, RS485, and digital inputs and outputs, and in terms of RAM and Storage it includes up to 4GB LPDDR5, a 32GB eMMC flash.
Previously, we wrote about the Mekotronics R58X RK3588 mini-computer, Mekotronics LS1200 live streaming box, and many other mini-PCs like the AAEON de next-TGU8-EZBOX, MINIX Z100-AERO, MINIX NEO Z100-0dB and many others, feel free to check those out if you are looking for a powerful mini-pc for yourself.
While looking at the specifications of this PC it looked very similar to the Mekotronics R58X but upon looking it’s clear that it has some differences, like it has now got a HDMI IN port and a HDMI Out port and it also got h RS232, RS485, ports.
Mekotronics R57 Mini PC Specifications
  • CPU:
    • Rockchip RK3576, Octa-core
      • Quad-core Cortex A72 @ 2.2GHz
      • Quad-core Cortex A53 @ 1.8GHz
  • GPU:
    • Arm Mali G52
      • OpenGL ES 1.1/2.0/3.2, OpenCL 2.0, Vulkan 1.1
      • Embedded high-performance 2D acceleration hardware
  • NPU:
    • 6 TOPS* for INT8
      • Supports deep learning frameworks: TensorFlow, Caffe, Tflite, PyTorch, Onnx nn, Android NN, etc.
  • Memory:
    • DDR: LPDDR5 32bit 4G, 8G, 16G
    • Flash: EMMC 32G/64G/128G; UFS 32G/64G/128G/256G/512G/1T
  • Video:
    • Decoder: H.264/AVC 4K@60fps; H.264/HEVC, VP9, AVS2, AV1 4K@120fps or 8K@30fps
    • Encoder: H.265, H.264 up to 4K@60fps; supports multi-stream encoding
  • OS Support:
    • Android 14, Buildroot, Debian, Armbian
  • Video Output:
    • HDMI output 4K@120fps or 8K@30fps
    • Type-C (DP1.4 protocol)
  • HDR Support:
    • HDR10 / HDR HLG/HDR ViVid
  • Video Input:
    • HDMI input 4k@60fps
  • Camera:
    • MIPI CSI
  • Display:
    • MIPI DSI
  • Ethernet:
    • Dual G-LAN network 1000Mbps x2
  • Wireless:
    • AP6256, 2.4G/5G WiFi and Bluetooth V5.1 EDR and BLE
  • Clock:
    • Support RTC clock
  • USB:
    • USB3.0, USB2.0, Type-C
  • PCIE:
    • PCIE 3.0 M.2 M-key), support NVMe SSD size 2280
  • Mini PCIe:
    • Mini PCIe for 4G LTE/GPS module
  • SIM Card Slot:
    • Support Nano SIM card for 4G
  • Audio:
    • Support MIC and audio jack
  • Industrial Ports:
    • RS232, RS485
    • GPIO with High/Low switch
  • DC Power:
    • 12V 2Ah (DC port 5.5×2.1)
  • Dimension:
    • 186 x 106 x 33mm
  • Weight:
    • 362g
Mekotronics ensures comprehensive support for multiple operating systems including Android 14, Ubuntu, Debian, and Buildroot. Additionally, the system seamlessly integrates with AI frameworks such as TensorFlow, MXNet, PyTorch, and Caffe through the RKNPU2 toolkit, a feature consistent with other recent Rockchip SoCs.
Mekotronics R57 fanless AI mini PC is available for $140 on the company’s website with the default configuration of 4GB RAM and  32GB of Storage. More details and purchasing options can be found on the products page.
About Debashis Das
view all posts by das
