![Melexis MLX90397 Micropower Triaxis 3D Magnetometer Melexis MLX90397 Micropower Triaxis 3D Magnetometer](https://www.electronics-lab.com/wp-content/uploads/2022/06/Melexis_MLX90397_IG-850x444.jpg)
Melexis MLX90397 Micropower Triaxis® 3D Magnetometer is a position sensor IC featuring Triaxis® Hall Technology and optimized for battery-powered designs. The MLX90397 measures magnetic fields along the three axis X, Y, and Z (Y being in a plane parallel to the surface of the die, Z being perpendicular to the surface). These measurements and the IC temperature are converted into 16-bit words, which are transferred upon request over an I2C communication channel. The device transmits compensated raw measurement data of the selected Bx, By, Bz, or a combination. The MLX90397 is designed for position sensor applications with a ±50mT range and an adaptative range on Bz of ±200mT.
The Melexis MLX90397 Micropower Triaxis 3D Magnetometer is housed in a compact 2.0mm x 2.5mm UTDFN-8 package ideal for space-constrained applications.
- 3-axis magnetometer device suitable for position sensors applications Triaxis® (Hall Technology)
- Low power operation
- 7nA typical idle mode current
- 1.7V to 3.6V supply voltage
- Compatible with I2C (0.1MHz, 0.4MHz, or 1MHz)
- Digital 16-bit output
- 16-bit magnetic (XYZ)
- 16-bit temperature
- At runtime selectable modes
- Magnetic axis selection
- Single measurement
- Continuous mode up to 1.4kHz (XYZ)
- Low 2µT noise for a 50mT range
- Ambient temperature range from -40℃ to +105℃
- 2.0mm x 2.5mm x 0.4mm UTDFN-8 package (JEDEC qualified)
- RoHS compliant and “Green” package
Block Diagram
more information: https://www.melexis.com/en/product/MLX90397/Triaxis-ValueOptimized-Magnetometer-micropower-consumer-battery
