![MicroBeast is A Z80-Based DIY 8-Bit Computer Kit MicroBeast is A Z80-Based DIY 8-Bit Computer Kit](https://www.electronics-lab.com/wp-content/uploads/2024/01/MicroBeast-Is-8-Bit-Computer-Kit.jpg)
MicroBeast is an eight-bit, Z80-based DIY computer kit built using readily available components. The device features a built-in keyboard, a unique 24-character display, USB-C for power, and various I/O options. Additionally, it integrates the CP/M operating system, which allows users to experience building and operating a retro-style computer using currently available components.
As an embedded engineer we all have worked with 8-bit computers, like Arduino, PIC, and many other controllers and processors. but most of those processors are overkill and include a lot of features that we often don’t use, but that is not the case for Andy Toone’s eight-bit MicroBeast Computer Kit.
The Z80 chipset is a famous microprocessor developed by Zilog in the late 1970s. It was a well-known CPU used in early computers, gadgets, and embedded computers. It was more advanced than similar chips of its time and played a big role in the early days of personal computers.
The Z80 CPU operates at 8 MHz and has 512 KB of RAM and 512 KB of Flash ROM. This ROM contains the CP/M operating system and a built-in monitor utility for managing low-level tasks. For I/O, it features a Z80 Parallel I/O (PIO) chip with two 8-bit ports, 12 GPIO pins, and a software-driven I2C interface, which is primarily used for the display and a real-time clock.
The MicroBeast includes a 16550 UART for serial communication, connecting to both an FTDI-style header and a USB-C interface via a CP2102N converter. Additionally, it features an RC2014-compatible expansion header, allowing expansion cards to directly access the Z80 CPU’s bus.
MicroBeast can be powered via USB-C or an auxiliary barrel jack. Additionally, there’s a work-in-progress emulator, BeastEm, which mirrors the MicroBeast’s core functionality, helping users evaluate the computer kit.
Features and Specifications of MicroBeast 8-Bit Computer Kit
- CPU: Z80 CPU, 8-10MHz.
- Memory: 512K RAM, 512K Flash ROM.
- Display: Unique 24-character, 14-segment display & virtual console.
- Keyboard: Integrated 47-key keyboard.
- Power: USB-C for power and data; auxiliary barrel jack also available.
- Operating System: Running CP/M 2.2.
- I/O Options:
- GPIO Header with 12 I/O pins.
- FTDI port.
- Speaker output.
- I2C Header for controlling I2C devices.
- RC2014 compatible expansion bus.
- Connectivity: USB-C for power and serial communication; built-in serial to USB adapter.
- Assembly: Comes with all components; PCB with surface mount parts pre-assembled; includes schematics and assembly guide. Requires basic soldering equipment and skills.
- Additional Features:
- Battery-backed real-time clock.
- Laser-cut keyboard frame.
- Kit is designed for expansion, customization, and hacking with full access to the CPU bus.
- Resources and Support:
- Online wiki for documentation.
- BeastEm Emulator for software development and debugging.
- GitHub for source code and examples.
- Discord channel for community support.
The MicroBeast kit can be pre-ordered on feertech.com, offered on a first-come, first-served basis with an estimated lead time of two weeks. It is priced at $240, with regional equivalents being £190 and €220.
