The MCP2518FD is a cost-effective and small-footprint External CAN FD Controller that can be easily added to a microcontroller with an available SPI interface. Therefore, a CAN FD channel can be easily added to a microcontroller that is either lacking a CAN FD peripheral or that doesn’t have enough CAN FD channels.
The MCP2518FD supports both CAN frames in the Classical format (CAN 2.0B) and CAN Flexible Data Rate (CAN FD) format as specified in ISO11898-1:2015.
- Conforms to ISO11898-1:2015
- Supports both CAN 2.0B and CAN FD
- Arbitration Bit Rate up to 1 Mbps
- Data Bit Rate up to 8 Mbps
- Up to 20MHz SPI Clock Speed
- Flexible FIFO Setup
- 31 FIFOs configurable as transmit or receive
- 32 Transmit Queue
- Misc
- 32-bit Time Stamp
- Bus Health Diagnostics and Error Counters
- Temperature Range: -40°C to +150°C
- Packages: VDFN14 (Wettable Flanks), SOIC14
- Low Power Consumption
- Low power mode current: 10μA, Max
- VDD: 2.7V-5.5V
- Active Current Max: 12mA @ 5.5V, 40 MHz CAN Clock
- Built-In Safety Features
- Loopback mode
- SPI commands with CRC to detect noise on SPI interface
- ECC for the SRAM 1 bit correction, 2 bit detection
more information: www.microchip.com
